I have 4-100 watt panels. Panel 1 - 100 watt, vmp 18v, imp 5.56, voc 22.0, isc 5.96.
Panel 2,3,4 - 100 watt, vmp 17.5, imp 5.72, voc 21.08, isc 6.22
I believe I have it connected as a 12 volts system in my mind.
All these panels are connected in parallel. The wires from each panel are 12 gauge connected to 10 gauge going into a housing with a buss bar that is connected to 4 gauge wire running approximately 25 feet to my garage to connect to the inverter. All the panels are earth grounded together and to a earth grounding rod. The panels are facing due South and have no sunlight blockage. I get sunlight from 8 am till right now 7 pm central time here in Tennessee. My panels are tilt able. My question is I keep burning up 1000 watt grid tie inverters. I don't know if its a electrical issue or what the problem is. Any help would be greatly appreciated. Thanks!
