Hello, I am sorry if someone question that. I have solar system with
- EASUN 5.5kw Hybrid Inverter MPPT 48V
- 4x solar panels Suntech 440w
- 4x Gel battery /12v 150ah/
- and Victron Energy SmartShunt 500A/50mV (settings on smart shunt is by default only I have change battery amp to 150ah because I am using 150ah and charged voltage to 52.8v)
My question is how to calculate value of bulk and float charging voltage and low cut-off voltage. I am using SmartESS app for monitoring and make settings. I have option to select battery type (AGM, Flooded and USER). I have now selected user mode and bulk = 56.4v, floating = 54.0v and cut-off = 48.0v. I am not sure is that settings are correct. And I need help for correct setting.
On battery label have:
- Standby use: 13.50~13.8V
- Cyclic use: 14.10~14.4V
Thanks in the advance.
