Will a MPPT charge controller work ok with a 19v battery? They say 12v or 24v and that they auto-sense. They also have custom profiles... but does anyone know if any will work with an odd voltage within that range?
Why? Because the biggest load on my system will be a laptop computer (max 230W; it's gaming computer with a video card), which specs 19v input. It's not only the highest max draw in my system, but probably the highest average as well. I'd hoped it would run on 12v (the battery is 3 cell, 11.4v nominal) but it does not. The laptop doesn't actually use 19v internally; rather it takes 19v and converts it to whatever the different components need. I suspect it would run on 24v just fine, since step-down converters usually do ok with a wide range of inputs, but that's kinda risky since I'm not certain.
So... if I built a 19v battery for the camper, the plan would be to use a 19v-12v DC-DC buck converter (these are cheap and very efficient) for 12v loads, which will mostly be lights. Maybe a refrigerator, but I doubt it. Possibly an electric blanket.
