eXodus
Solar Addict
- Jul 27, 2020
- 1,485
Hello,
I found this under bench mounted heatpump - it was released only in February 22.
www.pioneerminisplit.com
When I would be able to remove my ceiling mounted A/C unit - I could add about 900w more of solar. Further lowering the center of gravity.
Thoughts? Opinions? Ducting that thing will be a bit of a challenge also cutting holes in the floor.
Pioneer® 9,000 BTU 115V Under-Bench RV Heat Pump Air Conditioner $1200
Summary-
- Cooling capacity: 9,000 BTU/H with 8.5 EER efficiency 8.8amp - 995 Watt
- Heating capacity: 9,000 BTU/H with 2.6 C.O.P. 7.2 - 810 Watt
- Voltage: 110~120V, 60Hz, 1Ph
- Operational Temperature Range: 19 - 104°F
- Pre-charged with R410a refrigerant and ready to install
- UL Listed
- Perfect for RVs, Skoolies, Tiny Homes, Camper Vans, or any home on wheels
![RVHeatPumpAirConditioner9000BTU_1800x1800.jpg](https://cdn.shopify.com/s/files/1/1825/9663/products/RVHeatPumpAirConditioner9000BTU_1800x1800.jpg?v=1644723869)
![www.pioneerminisplit.com](http://www.pioneerminisplit.com/cdn/shop/products/RVHeatPumpAirConditioner9000BTU.jpg?v=1644723869)
Explore the great open road with Pioneer's newest RV heat pump air conditioner. Intended for under-the-bench installations, this low-profile and highly durable package system will keep your motor vehicle at a cozy temperature all year round, and do so quietly. Easily attach three ducts to serve...
![www.pioneerminisplit.com](https://www.pioneerminisplit.com/cdn/shop/files/faviconV2_32x32.png?v=1646172400)
