I have 2 bike batteries that I would like to use with an inverter during power outages. I likely will only ever use 75W max, but my battery is 48V, and most small inverters use only 12V. Does it make sense to buy a voltage reducer and small 300W pure sine wave inverter for this purpose or is that just making things more complicated? I already have an EcoFlow for my refrigerator/sump pump, so this is just for lighting and small electronics.
I was watching a DIY Solar review of inverters on YouTube, and he showed how you have to use a resistor to charge the capacitors before attaching the battery to the inverters. Is this true of small inverters as well, or just the large ones with large “surge” ratings? I assume that all the 48v inverters will need this procedure, which would be a little inconvenient for emergency use because I was hoping to solder the wires to an adapter that plugs directly into the battery, but I suppose that I could have 2 sets of wires if necessary. The video also mentioned grounding…. Is that necessary if only running from a battery?
Anyway, I’m hoping that someone can provide some insight into the best method for using these batteries, as they seem like they would be great for emergency outages. In addition, I’d like to use the system in winter to condition the batteries when they are in storage. Thanks in advance!
