I'm currently builder a mason 280 system; however the manual is a bit confusing regarding the torque (or well, the whole manual).
It says:
With this I think it would be:
The long bar with 3 horizontal screws: 1.5 - 2nm
fuse connector: 7nm
shunt connector: 7nm(?) looks too small for that...
the connectors for the terminal (m8 screws): 7nm
bms mount screw: 1.5 - 2nm
What did you use for this part?
It says:
with this image:Fix the battery terminal with torque index of 1.5-2 Newton meters, BMS with the torque index of 1.5-2 Newton meters, display screen of torque index of 0.5-1 Newton meters, fuse of recommended 7 Newton meters, and copper busbar of torque index of 7 Newton meters.
fuse connector: 7nm
