Solarfun4jim
Solar seduced :-)
Was looking at a 48V 300AH battery, which states that it is only 3840WH. By my calculations, i make it 14400WH....where am i going wrong?
Also, it states that it is Lithium Ion, but then states further down in the spec that the chemistry is LiFePO4. They seem to use the wording interchangeable. Is there an easy way to be sure of what you are getting from voltage specs etc?
Confused!!!
www.lithiumion-batteries.com
Confused!!!
48V 300AH Lithium Ion Battery
48 Volt Lithium Ion Batteries | Deep Cycle & Starting Lithium Ion Batteries. 1-855-GO-LITHIUM
![www.lithiumion-batteries.com](https://www.lithiumion-batteries.com/uploads/site/88/skin/Chargex-White-X2.png)
