I recently had a 2nd-life battery do something weird. The BMS shut down the discharge because one of the cells (it's a 2P-4S, 240AH, FLP battery, so technically it was 2 of the 8 cells) went to 2.3 volts. The other cells were all closer to 3.3 volts. I thought for sure something had gotten damaged beyond repair, but I slowly charged up the 2 cells until the deviation was less than 50mv. I let those two cells "rest" for about 4 hours and they showed very little drop in voltage, no more than you would expect right after charging. I was then able to start charging the entire pack and it seems to be charging normally.
Any thoughts on what could cause one of the cells to be fully discharged, while the other three were normal? I need to check all of the balanced leads and the harness, itself, to ensure that is behaving normally. (The cells are staying in balance, as they charge...within 20mv.)
