shadowmaker
Well, at the time I got suggestion to go with 16S with my panels from Deye tech, I didn't know/have the time to figure it out myself as I was busy building my system/working 85-110 hours a week at the same time. Also he probably didn't know how cold it can get here. When it's under +20C voltage is always higher than 650V thus over MPPT range (200-650V). Production seems to be ok though and my Deyes produce 10-15% more than my Bluesun15Ks which are always on their MPPT range (200-950V). Can't really tell why. I have also over 100m from my array to my "Solar Corner" so keeping voltages high reduces also transfer losses.Well I'd wait a bit.
There is a member here from Finland that also has the 12k's and he was told by deye to run as close too 800v as he could, if I remember correctly
Can't understand why, as it seems to me running anything over 550v will be lost, but he may have a good reason.
I stayed as close to 550v as I could ( 10 panels in serie) , but maybe I missed some insight
@shadowmaker
Maybe you can provide some insights ?
On cold (-30C or lower)/sunny spring days voltages do go over 800V hard limit on Deyes so can't recommend going this high to anyone. I have witnessed it once looking from Deye screen. I saw voltage going up slowly to 808V and tripping inverter. Immediately after that voltage went slowly down and after 2-3 minutes or so Deye started working again after dropping under 780V. From the log I see this happening 10-20 times each spring so maybe I'm playing with fire, actual fire.
