Tom Morrissette
- Jul 10, 2021
- 4
Hi all. My first post here. I'm venturing into the diy battery/solar realm with a system for a new truck camper (Lance 850), and a boat (23' World Cat with twin 2005 Honda 150hp outboards).
The camper comes pre-wired for up to two solar panels and two battery boxes (I have to check what kind of charging system it has factory installed). The boat takes two 12v cranking batteries and one deep cell house battery (all agm currently), that charge from the alternators and a Noco genius three bank shore power charger (will have to check model).
My plan is to buy 20, EVE 280ah, 3.2v lifepo4 cells. I'll build two 12v's for the camper (8 cells), and three more for the boat (12 cells). For now I plan to keep the agm's I have, and use the three lifepo4's (wired in series) for a 36v trolling motor (When the agm's are nearer the end of their life, I'd like to replace them with diy lifepo4's as well).
I think I have all the information and resources I need for the batteries (although all advice is welcome!), but my big question is: what is the best/most efficient way to configure solar to charge both the boat's 36v bank, and the camper's 12v bank?
I'd probably like to mount at least two 100w panels on the camper. I'd like to use four 100w panels total, but I'm not sure about space (especially on the boat). Assuming I can figure the space out and decide to build a 400w solar charging system, is there a good blueprint could I use, and what components should I consider in order to charge both the boat's 36v bank, and the camper's 12v bank?
Most likely, I'll keep the whole solar system with the camper, and plug the boat to it when it's on it's trailer, although I'm open to having separate systems, with probably just one panel on the boat, if it doesn't add too much cost (but it would be very rare, if ever, that I'd need more than 280ah on a boat trip). Is my best option to just use an inverter to run a designated 36v charger for the boat?
Thanks for anyone patience enough to read through all this! Look forward to your replies.
