hi all, currently weve got 3 solar arrays, ( due to the orientation of my panels) we have 2 arrays both with 2*400w panels, these are facing s/e and 1 array which is 2*250 panels.
Each array is connected to victron mppts and i have a victron 24/3000va inverter and 4 lithium LiFePO 4 batteries wired in 2s2p.
I use this mainly to power my offgrid office and lounge entertainment system including tv. there have only been a few days when i have had to rely on mains power since i set this up last september, anyhow i am thinking of changing to a 48v system, currently when i get full sun the mppt stops charging, when we get full sun i regularly use my setup to boil kettle / use air fryers / toasters etc. I have used the air fryer for 1.5hrs and still the batteries were fine to run the lounge and charge the delta 2 + extra battery and keep the pc and mac going till 6pm
my question is - is a 48v system harder to charge in low light conditions such as we regularly get in the uk, in summer i am sure i will be able to charge the 48v battery(s) as my panels get sun from 10 - 2 ish and the 500 w array gets sun from 12 - 4, will i need more panels to keep the battery topped up ? anyone else in the uk using a 48v off grid system with around 2.1 kw of solar
