400bird
Solar Wizard
That's no the case at all. There's no "minimum amount of solar per inverter"
But an inverter uses energy just being turned on. This adds up pretty quickly. Over 1kWh per day.
If you don't need the output of two inverters, don't waste the energy to run two inverters.
If you are unsure about only needing one inverter, you could run all you PV into one inverter, call it primary and run it all the time. Then connected the second inverter, but leave it off most of the time unless you need to run a large load.
