Simpleone71
As the title states, I have called nine different electricians in 3 counties and they either come out and review things and never call back or several have just not called at all.
So this is looking like a do it myself job and I just wanted an extra set of eyes on my plan here if you all would be so kind.
I have an inverter in the back bedroom of my house and my fuse panel is on the other end of my house in the garage. I did not place the inverter near it as I live in Georgia and from what I researched, it is not recommended to put the inverter and batteries in a unairconditioned space. It is a smaller house at 1800 sq ft.
I need a wire from the fuse panel to the inverter to charge the batteries. I have a Victron 48/5000/70-95 120v inverter but will not be using power assist and will be limiting my charging rate to 50a. I am thinking I will use 6/2 MC on a 60amp breaker which would meet the 80% rule for constant use.
I will also need a wire from my inverter back to the fuse panel for my 6-circuit transfer switch (Reliance Pro/Tran 2 #306A). I am thinking 6/2 MC for that also as my transfer switch has a max limit of 60 amp.
Finally, I will use 8/2 MC for the PV from the panels to the MPPT. I have a Victron 150/70.
By using MC wire, it will come in conduit since the wires are THHN. While I can get 6/2 in NM-B, it then is derated to 55 amps and since you can't get a 55 amp breaker, I have to go down to a 50 amp breaker. Then the 80% rule would take me to 44 amps.
From what I have read, in most areas, PV wire must be in metallic conduit, which this would meet.
Does this all sound right and seem to meet code in most areas (I know code is different in each town/city/county, just making sure I do not have a massive violation).
