I currently have a 16kW AC (enphase micro inverter) that’s net metered at my house. (On a high roof that I don’t want to have to go on)
Buy and sell is a flat rate (17.7 c/kW). Halifax, Nova Scotia
I think I need around 22kW more solar to reach net zero.
I’d like to add a ground mount with several DC strings to make up the 22kW. I have 2 x 200amp panels in my house and would like to add a small battery bank that’s expandable, and be able to use my solar when the grid is down.
I have a Sol-ark 15k at my cottage (fully off grid)which is way overkill as I only have 6,500W of solar there. My thoughts are to get an off grid hybrid inverter for my cottage, and take the 15k to the house. I would like to be able to use the 16kW AC when the grid is down as well, but not sure what the best set up is. I know a single 15k can sell back up to around 30kW of combined DC and AC solar, but would I be a lot better off going with 2x 15k’s, one on each 200amp panel, and put half the DC and Half of the AC on each one, put all the AC on one and DC on the other, or some other combination?
I only have a 7,000W gas generator at the house that I can use when there’s no sun (our outages are normally fairly short but can be up to 3 days). I think a chargeverter would be best for charging on those occasions.
What route would people with similar experience/ installations recommend I do?
Thanks in advance!
Andreas
Thanks in advance!
Andreas
