chadjones99
chadjones LLC
So here is a weird question does altitude affect the output of your inverter ? Now I'm not talking about inverter generators, I mean inverters. I will get to why I am asking and what I found and did not find.
So the back information is as follows: I have an 8 kw growatt inverter, and I'm am camped off grid in the Colorado mountains, my altitude is about 7800 ft above sea level, and a few weeks ago when I got my system online, I wanted to stress test it. I have my 50 amp Rv plugged into the 50 amp solar system plug and I proceeded to ( monitor ) add loads, 1st electric fireplace, all good ( only like 1500 watts ) then the microwave, coffee pot, and an electric water heater. total loads hit I believe 5300 ish watts and then the power dropped out , by the time I got out to the growatt inverter I did not see the code (the fault light was on and I cycled power to reset ). So I could not figure out why it tripped offline at 5300 watts. So I started searching the owners manual and found a very short note that the inverter will de-rate itself above 2000 Meters, well that's about 6500 ft above sea level, and I'm at 7800 ish feet , but what stumps me is ok I get why generators are de rated but why would solid state equipment care? I searched another growatt owners manual and it states for cooling, but it also has a temperature de rate function so why would it need an altitude de rating mode? and how can it tell what the altitude is. This got me curious so I searched my go power inverter manual and it doesn't state anything about altitude, and not all growatt manuals do either. one 8 kw inverter manual does and the other manual I found for a 8kw growatt does not.. So I wonder if this is what trip my inverter?
this was the statement I found :
The inverter uses natural convection cooling, if the installation site’s altitude is
greater than 2000 m, the inverter may trigger de-rating protection. Altitude and
output
output
