sjordan0228
Hey everyone. I have a small shed I am building out. I have decided on a eg4 6000 for the inverter, eg4 48v 100ah battery and around 1600 watts of solar to start. I will eventually expand batteries and solar.
I went to Home Depot today and bought 12/2 wiring, wall boxes, and receptacles. Where I am confused is the breaker box. I am clueless on what to get here. I don’t need 240, everything I am running will be off of those receptacles I am putting in and a 120v mini split AC.
So do I need a sub panel or a main breaker? I will have no other power coming into this. It’s completely off grid. I saw this at Home Depot. Would this work?
If so what’s the proper way to do this? Hook it directly to this load center, hook it to a 60a breaker? I am assuming I need to get a grounding bar and ground it outside the shed.
Sorry for the ignorant questions. I will have a friend who is a electrician helping but I want to learn
Square D Homeline 100 Amp 6-Space 12-Circuit Indoor Surface Mount Main Lug Load Center with Cover HOM612L100SCP - The Home Depot
The Square D Homeline 100 Amp 6-Space 12-Circuit Indoor Surface Mount Convertible Main Lugs Load Center is UL listed for residential and commercial power distribution. This load center is built with a
www.homedepot.com
