bikerider4818
Attached are Will Prowse's pictures of how he wired his 4 batteries together and then to his two 6000xp inverters. I will eventually have four batteries also and I'm trying to figure out the best way to wire them. I don't quite understand what he has going on here and I don't think I can recreate it if I end up with 4 Lifepower batteries because of the size of the battery lugs. I also don't see a communication cable being used. I already purchased bus bars from Signature Solar (see picture). Is it better for me to run 4 cables from the inverters to the larger bus bars and then on to the batteries? Or run the 4 cables to the smaller combiner bus bars (see picture) then to the longer bus bars and then to the batteries. What cable sizes depending on the configuration?
