Battery Disconnect Switch OR Resistor?
Is the 15V DC power source required for a 12v Multiplus II and not the 24V Multi?
It has to do with the battery BMS. My 12V SOK batteries would not wake up until I applied 14.8V or more. I used a bench power supply to find out what it took to wake them up.
I'm sure all BMS's are different. Maybe not. You would have to get your BMS to go into protect then put a power supply on them to see what it takes to wake them up.
A downside to the precharge circuit is if the inverter decides it needs to reset for some reason. When it powers back on, it may send the BMS(s) into protect. That happened to my wife as well.
When the inverter takes a break, ya gotta remove the loads immediately before it restarts.
Is wife proofing even possible?
I highly recommend one of these to keep an eye on your load. You can configure a contact to operate a warning device at a selected current level
Wife proofing is expensive. But I really want her to like glamping so she will go on the road with me.
And just to be clear, not all BMS's have issues with all inverters. Had I stopped at the Xantrex 2000W inverter, I would have never known about precharge circuits or sleeping BMS's.
Wow that’s a lot of voltage to wake up. I’ve heard of some that need this.
I friend got a bunch that the previous owner thought were dead but they just needed waking up.
Gotcha. I have a wake-up button (I have to swap it in after removing UART Bluetooth dongle - v2 BMS limitation) on my Daly BMS for that situation.
Haven’t found anything wife proof or ease the pain of a verbal dig. Yup got the button on the box too.View attachment 210296
Can you share what is inside with parts list? VERY clean solution! I like the indicator light to show the voltage difference. Does the light go out once the voltage is equalized/capacitors are charged?
The FETS are there to shut down as a last resort and the inrush is massive and so fast that it’s usually waaay more than they are rated for. Hold down a momentary switch for 5 seconds to a 25 watt 30 ohm resistor right before you close the switch is cheap insurance. There’s just no need to beat up your system. When a charger powers up from the AC side, you may hear a groan from an inrush but the power line and transformer greatly ease this in comparison to the potential of a battery. View attachment 210294
Instead of using a 25 watt resistor, I use an incandescent automotive lamp. You push the switch button and the light turns on an then immediately starts to dim as the voltages even out. When sufficiently dim, let go of the switch. The big functional advantage of the light bulb, versus a resistor, is the visual feedback that confirms the pre-charge circuit is working and knowing when the voltages are sufficiently even. You can get automotive bulbs in 12V (obviously), 24 V, and 48V. The 48V bulbs are sold on Amazon as "forklift bulbs"
In my current RV solar power wall, I use a 600amp blue sea rotary switch as a quick connect between the Lifepo4 battery and the rest of the 24vdc system (inverter charger, solar charge controller and secondary 24vdc charger). I turn the blue sea switch "ON" before I switch the Aims inverter "ON" and switch the PV breakers on that feed solar to the solar charge controller. When I upgraded from 24vdc/200ah to 24vdc/600ah, my 300amp blue sea switch would overheat and fail. The 600amp switch appears to handle the 'rush'. It still makes a hot sound when the amps rush through it initially. I then turn on the Aims inverter.
Q: Before I switch to my Victron Multiplus II 24v 2x120 inverter/charger, do I need to add a resistor to bypass the power switch and pre-charge my Victron inverter capacitors? Does my blue sea switch act as a sufficient resistor between the battery and inverter, rest of the 24vdc systems?
As others have pointed out, you really need to precharge (for SECONDS) with the resistor to prevent catastrophic damage to the inverter's circuit boards, wiring, and the switch contacts from massive overcurrents as the giant capacitors are suddenly charged from giant batteries. When you connect a capacitor to a hard voltage source (without inductance between - which causes other problems), you dissipate as much energy in the wiring as you store or remove from the capacitor, and the lower the resistance, the higher the current (up to near infinity if the resistance is very low). You want to dissipate that energy in a resistor, which is DESIGNED to turn electrical energy into heat without slagging down in the process, rather than in the circuit board traces, the capacitor "plate" foils, and the tiny area of the switch contacts' initial touch, and do it slowly enough that the resistor can handle the job.
Since you're using a rotary battery switch for shutdown, here's a hack. (It's cheap, except that you may need to buy and swap in a different model of the switch.):
* Use a two-battery selector/combiner version of the switch.
* Hook the battery to the "battery two" connection.
* Hook the precharge resistor between the battery one and battery two connections.
So setting 1 is precharge, setting 1+2 and 2 are battery. When turning on switch from off to 1, wait a few seconds, switch to 1+2 (then onward to 2 if you feel like it). Turning off: switch to 2 and then off (so you don't switch to "resistor in circuit" when there is high current or charging current running through the battery line.)
If your "resistor" is an incandescent bulb, I'd wait until it was too dark to see for at least as long as it had been visibly lit after you started precharging. The precharge goes slower as it approaches even, and switching to zero resistance even when the voltage mismatch is small may still produce damagingly high currents.
NOTE: I 'assumed' the switch provides the resistance/protection given it has 'ignition protection' built in. My Aims inverter/charger has lived happily in this configuration since 2021.
Not sure, but I think "ignition protector" is a metal oxide varistor from the output terminal to ground, to keep the alternator voltage from spiking and burning out your electronics (including maybe the alternator's regulator) if you switch the batteries off when the engine is running (in a typical boat installation). The battery load normally clamps the voltage so that it doesn't go too high, but disconnecting it suddenly while the alternator is charging the battery will cause the voltage to go 'way up for much of a second while the regulator tries to reduce the excitation (which takes a while because of the inductance of the field winding).
If possible, my preference is to have the solar always charging the battery pack - 100% of the time.
If you just turn the inverter on / off by itself, then you don't have to worry about the pre-charge.
What about night time?
Really? So, as long as the inverter switch is OFF when I turn the battery switch on, there is no risk to damaging the inverter? Then, I just turn the inverter on after turning the battery on? I thought purpose of precharger was to prevent a surge when turning the inverter on.
My current system using Aims inverter/charger and Aims solar charge controller is on 24x7. The only time it is 'down' is if my BMS shuts bank down due to protection fault (RARE) or if I shut the system down for maintenance. I am preparing to add the Multiplus II and Smart Solar MPPT in place of the Aims to get VRM monitoring of AC IN/OUT, Solar PV and DC load.
My system is on 24x7. The only time it is 'down' is if my BMS shuts bank down due to protection fault (RARE) or if I shut the system down for maintenance.
It is. Won't help to have the inverter off before turning on batteries and then turn the inverter on. At least not with my MPII. I tried that.
I wouldn't want to deal with having to hold a button to get things started. I have 2x 48v 100a SOK batteries and 2x 5kw quattro inverters. 50% of the time they start just fine without any precharging or anything, and this is at night without solar. They have built in precharge but I never remember how. I'm not sure if the inverters capacitators stagger start or what, as to restart the inverters I need to turn off then on and they have separate switches so take a second, also they sync up.
If that doesn't work I just turn the key to on and then it'll use the chassis dc converter to precharge, then i'll reset the bms on the batteries.
I think I broke my EG4 12V battery BMS's as I don't think they do anything anymore. I've seen the alm light come on sometimes but they still work.
The input capacitors on inverters can draw a lot of current really fast when they are charging. LiFePO4 batteries can provide a lot of current really fast. The BMS might see this as a fault and put the BMS into protect. Now you have to find a way to wake up the BMS which is not as simple as it sounds.
My SOK batteries had no issues with a 1200W or 2000W Xantrex inverter. They really did not like my Victron MPII 3000. They went into protect every time. The precharge circuit charges the inverter caps before you connect the batteries. A simple, elegant and cheap solution.
If you forget to precharge, you will have the pleasure of tracking down a 15V DC power source to wake them up. My solar wouldn't wake them up. My truck charge line wouldn't wake them up. A smart 120V battery charger wouldn't wake them up. I made a small battery pack with a buck converter to wake them up. What a giant PITA.
Thanks much.
If the power system in general is kept in an always on state, then the inverter input caps will also stay pre-charged.
Then you can just use the switch on the inverter or the remote to turn it on. The main reason to turn an inverter off is the 20 - 30 watt standby power when it is on.
Once you have 300 + watts of solar on a vehicle that is parked outside, the only reason that I would turn off the power system is to work on it. My explorer just has 150 watts because that is all that will fit on the roof and I just turn the inverter off when not in use, but I only use that thing for running power tools.
There isn't any reason to turn off the breaker between the battery pack and the inverter normally.
If you have enough solar to keep the battery 90% SOC even with the inverter on - just leave it on all of the time.
Just had a situation where a precharge would not have worked. I've had this happen before. I was load testing my new install. Had one a/c fan on (500W) then turned the fireplace on low (900W), then high (1500W). The inverter shut down. It went through it's reset cycle then came back on. All was good with my surge limiter. But if that happened with just a precharge, my BMS(s) would have gone into protect and I would be cursing.
The inverter reset because I only had one battery hooked up and 2000W overloaded the one BMS. Oops. I flipped the main 50A CB off before the inverter reset to prevent another overload.
Just want to confirm where the pre-charger fits in the schematic diagram. From this image, the wires are coated red. I note on the Battleborn capacitor limiter, it says to connect between Bat negative and Inverter negative to precharge. Is this correct?
From the AI on Google search: "The Blue Sea Systems E-Series Master Battery Switch Single Circuit is typically used between a battery bank and an inverter. It is slightly larger and has a higher current rating than the High Current On/Off Mini Switch (6006). It is recommended to use this switch with 3000VA inverters."
I received my resistor and pack of LEDs. I have installed on a 1-OFF-2 switch. The resistor is much further away from the OUT pole than pictured.
