nschizzano
Regarding a charger from the gasoline generator. What is the best and fastest charger for this 200AH 12V battery? 100a will work?
Send links please.
Here are the charging parameters ️
Charging Limit Voltage: 14.6V
Over Voltage Disconnect Voltage: 15V
Over Voltage Reconnect Voltage: 14.2V
Equalizer Charging Voltage: 14V
Float Charging Voltage: 13.8V
Boost Charging Voltage: 14.4V
Boost Reconnect Charging Voltage: 13.2V
Low Voltage Disconnect Voltage: 10.8V
Low Voltage Reconnect Voltage: 12.4V
Under Voltage Warning Voltage: 11.6V
Under Voltage Warning Reconnect Vltg:12V
Discharge Limit Voltage: 10.4V
Over Discharge Disconnect Voltage: 10.4V
Over Discharge Reconnect Voltage: 11.6V
Over Discharge Relay Time: 0.8s
Equalize Durration: 120MINS
Boost Durration: 120MIM
Send links please.
