BMS as primary LVD?
brianjonesphoto
Seattle-ish
I’m building 8s 304ah storage battery to power boost converter chargers for dc to dc charging of electric dirt bikes. The boost converters do not have a low voltage disconnect. I’m thinking I should have a primary LVD and use the bms as redundant. It would be up to a 100amp load. Is there an option better than a cheap set table 10amp LVD from Amazon triggering a decent contactor?
My low voltage disconnect is the BMS. Best to build a system where LVD would be very uncommon.
Yes, you can use LVD module to drive the contactor, I would get on that can handle 125A or more.
