MotoVan
- Feb 19, 2021
- 6
Greeting, everybody!!!
I have 16 Shenzen Basen 280 Ah cells in a 4p4s (12V) configuration. It is 14 kWh, and it will be used in my motovan to charge my two Alta electric dirt bikes.
![IMG_20210218_2128509.jpg IMG_20210218_2128509.jpg](https://diysolarforum.com/data/attachments/37/37717-6c2af4a5ed71471f93d59d37b04770e0.jpg)
I can't seem to find a good charger or a good BMS. I want to be able to balance the cells.
Right now I have an iCharger 406 Duo. It is good for 70A, which is fine when charging from shore power, or from the alternator.
But it has several major flaws:
1) The charger input ground can NOT be connected to the charger output ground. If connected like that, it says it will blow up. If I charge from a 110V power supply, this is not a problem. But what if want to charge from the alternator? I can add an isolated $300 DC-DC converter, but this will be an inefficient and bulky $300+$300=$600 solution.
2) This charger is not a BMS. It has to be started manually. Not a big deal though.
3) The charger, apparently, has to be powered on before it is connected the the battery. It still works if I power it later, but the manual says not to do it.
So.... Are there better charger or BMS options?
