TenagaSurya
This pair of diagrams shows my plan for a solar panel and inverter upgrade to an existing simple 12v alternator-powered lead acid battery setup in an old Volkswagen T4 campervan. Main loads are a small fridge (nonstop) and a 600w inverter for charging three laptops and occasionally running a tiny kettle.
The first image is stage one of the plan, mainly adding fuses, a shunt & monitor, battery cutoff, inverter and portable solar panels. The second image is the same but with the addition of a DIY lithium battery (size to be determined after trialling the new setup) and a DC to DC charger to avoid trouble with the stock 90A alternator. Sorry for hurting people’s eyes, my awful schematic looks like a birds nest - let’s hope it doesn’t end up that way for real..
I am hoping for comments/criticism from any of you kind forum folks before I begin (re)wiring the van. I also have the following questions I am hoping for some advice about:
1. Do I need to fuse all the inputs from low wattage solar panels? If so, at 12v and currents under 20A are inline (small) blade fuses good enough for that?
2. I already bought a single-pole breaker to disconnect portable solar panels and avoid any arcing. But now from reading the forum now I see people usually disconnect both pos and neg - why is this?
3. Is it safe to use this charger that came with the 200w solar blanket or is it likely to overcharge batteries? I am assuming it is not genuinely MPPT as it claims but rather PWM. The manual claims “Voltage of stop charging 14.7V”. It is not manually adjustable nor even selectable for battery chemistry. [https://cdn.soselectronic.com/productdata/d2/9a/7866275a/mpl15.pdf ]
4. In the future upgrade where I add a LiFePo4 battery, is it possible to use my existing mains-powered lead acid charger as the input to a Victron Orion Xs DC to DC charger, rather than throwing it out? In which case I could wire it in on the DC to DC charger side of the voltage sensitive relay.
5. What to use for strain relief / to restrain cables in general? I have a roll of wide double sided velcro I am thinking of stapling to the wiring backboard and using for tidying cables. But it won’t provide substantial strain relief.
Stage one:
![Campervan electrics diagram draft v1.0.png Campervan electrics diagram draft v1.0.png](https://diysolarforum.com/data/attachments/232/232869-bcd8a8206c91e3bc21b054c5af942dae.jpg)
Stage two:
![Future additions Campervan electrics diagram draft 1.0.png Future additions Campervan electrics diagram draft 1.0.png](https://diysolarforum.com/data/attachments/232/232870-9d047e33ab3d889672cad994569e4ca4.jpg)
Stage one:
Stage two:
