I have a dedicated 175amp (14.4v) alternator on my Beta Marine 42 engine, there's a seperate smaller 45amp which charges the starter battery and cockpit circuits.
For habitation batteries I have two 16s 280ah eve cell batteries (total 560ah @ 48v)
Using a B2B charger is the obvious answer, but it's abit annoying spending many £100's and still being down on charging amps (roughly works out to something like £300 for every 30amps) I could drop £900 and still only be using 90amp...
I've seen these
I've done abit of reading about the pitfalls of charging lithium with an alternator, the main ones being the low resistance causing the alternator to run flat out and at low RPM the alternator gets too hot... and if the BMS turns off the alternator may see that as infinite resistance and run flat out again.
I've ordered five of the these boards and I'm playing with the idea of wiring them in parallel (each one with a seperate breaker) and using a raspberry pi along with a multi channel digital potentiometer to control the current limiting side of each board in relation to alternator temperature (use a temperature sensor input) The other issue seems easy to solve by using a SSR to disconnect the alternator Excitor wire with the BMS sending signal to one of the Raspberry Pi pins.
Link to multi channel digital potentiometer
https://www.analog.com/en/products/ad5206.html#product-overview a raspberry pi can control this using its SPi pins
What I would end up with is a 55.2v bulk charging supply, with current limiting based on alternator temperature and alternator cut out, I dare say I would then be getting very roughly something like 40amps going in provided RPM/cooling allows it.
does anyone have any input or ideas, maybe something obvious I've missed or other issues/challenges?
thanks for reading
I've seen these
1800W 40A Max Boost Converter Step Up Power Supply Module Constant Curren s,1 | eBay
(Module nature: non-isolated boost module (BOOST). (The step-up module cannot be directly short-circuited to adjust the current). Constant current range: 0.8-22A (+/-0.3A). Small differential pressure and high efficiency).
www.ebay.co.uk
thanks for reading
