Connecting to Solax X1- Hybrid G4. Lan Dongle
allanicars
Nottingham
I've had the Solax Inverter and battery installed since December, and it was working with the Pocket wifi V2.0 dongle, however as the system is in the garage I was getting drop outs on the wifi. I did connect a wifi extender into the garage and this improved the situation, but it was still lacking. I recently purchased a pocket Lan V2.0 dongle and installed it, but since doing this, I noticed that the ports are no longer open ( they were on the wifi) and I need the port access for my home assistant setup. I can see the IP address the Lan dongle is using, just there isn't any port access.. is this something that needs to be setup in the inverter?
Also whats the difference between the Pocket Lan V2.0 and the Pocket Lan V3.0 (apart from colour)
