Rui Ponte
- Nov 25, 2019
- 73
To add extra protection to my DIY 48V 560Ah battery, I was thinking on adding a low/high voltage disconnect, controlled by the Batrium BMS.
Question 1:
I noticed that a lot of people recommend the Gigavac EV200/GV200
Here, €125+Shipping https://evshop.eu/en/relays-fuses/13-gigavac-gv200qa-contactor-48v-external-economizer.html
Could these two be viable (cheaper) alternatives?
Dianqi ZJ200A ($25,3+VAT) https://aliexpress.com/item/33001621718.html
SSR-200DD ($25,23+VAT) https://aliexpress.com/item/4000295498163.html (does this SSR have the specs I need?!)
The battery will be fused at 200A.
Question 2:
My Victron Multiplus II and Batrium can talk to each other via can bus, namely in regard to charge and discharge limits:
(more details: https://support.batrium.com/article/111-how-to-control-victron-venusgx-with-watchmon)
Additionally, the Victron inverter also has “allow charge” and “allow discharge” external contacts that, I believe, can be controlled by the Batrium.
(more details: https://www.victronenergy.pt/upload...battery-systems-to-Multis-and-Quattros-EN.pdf)
I still haven’t configured the two together but, If everything works seamlessly together, will I be wasting my money on the above mentioned contactor?
Or one can never be to safe, and it would be a good idea to add the contactor as a failsafe, in addition to the Batrium-Victron communication?
Thanks, and sorry in advanced if I’m asking something stupid ?
Question 1:
Question 2:
