This is driving me nutty! I need two DC power ends that I can plug into my fans in my chicken coop. I don't want to cut the end off the plug, because I may use the fan portable at times. I found the screw on type, but they only handle 16-26 gauge wire.The fans run 1.25 amps and one will be 18 ft from the fuse block, so I will be using 14 gauge wire and the other fan is 35 feet from the fuse block, so I will be using 10 gauge wire. I can't find DC ends that will work with that gauge wire. How do I do this?
TIA!
TIA!
