atothex
- Jul 5, 2022
- 8
Hey guys I need some help with my BMS of a battery from AliExpress.
I own two of those batteries,
1x 100Ah - BMS: 16S100A
1x 150Ah - BMS: 16S200A
![Lifepo4.JPG Lifepo4.JPG](https://diysolarforum.com/data/attachments/111/111937-65a40406830748d788035da238a53e4b.jpg)
I have the batts on a Deye 12kw Hybrid and everything works fine.
Some days ago i contacted the seller to send me some information for setting the charge rate, reported by the BMS to the inverter. I used the software and read out the configuration to alter the settings because the charge rate of the 150Ah battery was a little low 0,15c i guess.
Well he came up with a firmware file i should use. Ok i asked him if i can use it on both batteries because they have different BMS versions (100A and 200A). Well all good i shall go ahead and i did it. Thats the firmware he send me.
![IMG_E4454[1].JPG IMG_E4454[1].JPG](https://diysolarforum.com/data/attachments/111/111938-c0968c1add3cfbef3a300b007f76f33c.jpg)
All went good nothing blew up and my problem with the low charge rate was solved. Both batteries reported 160A combined (a little high but i can reduce it by the deye).
Now to my problem:
A day later the 150Ah battery threw out a undervoltage alarm.
It went out that the SOC was way off and wrong calculated. I had a felling and it went out that the 16S200A BMS showed amp readings way of the reality
![real amps real amps](https://diysolarforum.com/data/attachments/111/111939-856b37b0a472bb00ab06527b78672f6a.jpg)
![BMS amp BMS amp](https://diysolarforum.com/data/attachments/111/111940-e2c82a084e8ee0799b8ae40781b98b23.jpg)
The 200A BMS (right picture) ) reports roughly ~0.5*A for the charge rate. Discharge the same.
Ok i didnt freaked out, i thought the calibration of the internal shunt was not right. So i tried to calibrate it by the software.
Well, it didnt worked out for me. I was able to calibrate the reading of the BMS a little but the factor 0.5A stayed mostly the same.
I guess the calculation is hard coded in the firmware file for the different BMS versions.
I read a thread that a JK BMS showed a similart behaviour and searched for a similar parameter to set the resistance in the software.
But i couldnt find anything related.
Maybe someone has the correct firmware file for this 16S200A BMS or an hint how i can fix this in the software.
Many thanks guys!
Alex
Now to my problem:
Many thanks guys!
Alex
