Hi there,
I'm running two 12v 280ah EVE cells with JBD 200A BMS in parallel. All seems to be working well but when I check the status of the BMS I notice a difference in the 'session values'. According to this information one battery seems so get a lot more discharge then the other one. I don't understand why as the voltages of the cells are mostly equal, with a difference of only a few thousand volts.
Where does this difference come from?
Sessions values:
Sessions values:
Bat 1 | Bat 2 | |
max volt | 14.21v | 14.21v |
max chg | 30.53A | 20.25A |
max power | 2452 w | 1417w |
min volt | 12.79v | 12.84v |
max dist | 186.75A | 107.91A |
