Dasfriek
Im stuck and cant find my answers on the whole web.
DIY car audio is mostly clueless on this subject.
My main questions are this.
i have a 96ah headway battery with 48 cells
another 64ah headway battery with 32 cells
and lastley a Yinlong 2 bank 80ah battery With 12 cells.
they question is what bms does each need, i did read the 64ah 32cells 4x8 cells headway needs 2x 4s12v100amp bms, or do i just need a balancer or is that built it?
so what BMS for the 96ah headway. 48 cells btw. Not sure on the cell configuration.
The yinlong is 12 cells 2x8 configuration.
Is the info on the 64ah headway info correct?
SO what does the 96ah cells need?
and the Yinlong also.
Sorry. To be in the wrong forum. But your my last hope on this.
Some back ground this needs to run an 8k-10k watt car audio system.
i currently am running 2 large AGM batteries, Then an isolator and have 2x XS Power 29.7ah and a supercap bank ready to go in.
