Moto
New to solar... Just trying to price/plan a system.
I just want to verify it is OK to have a different number of panels on each MPPT input on the EG4 6500 EX-48?
I assume each mppt works independent of the other, but I wasn't able to find anything other than max inputs in the manual.
In my head most pallets come with 30 panels per pallet. To get things to work I'd do a couple of rows of 8 and a couple of rows of 7. (Probably15 panels per EG4 6500 EX-48)
To rephrase my question....
On most all-in-one units do the MPPTs inputs work independent of one and other as long as you fall in the specified voltage/current range of each MPPT?
Background:
I'll probably have a few more brilliant questions before everything is said and done.
- I'm trying to figure out if I want to install a solar system at a manufactured cabin this summer or next. I have an existing electrical service in a shop about 150ft away. It looks like it is sized at 100 AMP. I'm hoping to go solar and use that as backup for a couple of EG4s or similar.
The trouble with the cabin is I don't really have a good grasp on how much power it will take. I don't have a full appliance list and we have some old appliances from a farm we demolished. I back of the napkinned things but I think I was over sizing the system given the place will mostly be used in the summer. Was planning 12000W to 14000W worth of solar and maybe 20KWH of batteries.
Really the washer and dryer set is the only thing I'm worried about. They are both near commercial sized speed queen units out of the old farm house. (going in the garage that will share power)
The cabin is all new stuff and I'll probably put in a 24000 or 18000 BTU mini split heat pump. ~400 sq/ft
Background:
