MisterB1959
- Oct 22, 2022
- 365
i realise many people have already carried out some sort of 12v conversion and flat mount process, but i thought i would bring this you tube series to the fore. Its based on some great work by Oleg Kutkov from the Ukraine who has carried out quite a few repairs to keep their Starlinks working. check out his blogs on line they are really interesting for anyone looking to make changes .
The videos (3 part series) Its a 12v conversion that i have already undertaken (the you tube videos are NOT mine). i like the videos as they show everything, warts and all including mistakes they made and how they would do it differently,
the videos can be found by searching for Offgrid Power Solutions - not sure if you tube links are allowed?
i have already succesfully got the 12v starlink working with a one cable input, i used a standard ethernet cable WITHOUT POE by dedicating four wires from a router for the data and the other four, twisted into two pairs, to supply the power. so its a basic setup, router powered by 12v, the ethernet 'power' wires also supplied by 12v at the same pint as the router. when the ethernet goes into the dishy (i call it FranK Starlinkenstein) the cable splits again into the separate 12v and data feeds.
it reduced the data stream to less than 100mbs, but i can live with that download speed.
Not content with that i am now experimenting with stripping out the original router circuitry and installing inside the new starlink housing. this will allow me just to use a single 12v cable as all the router bits will be inside the housing -
so i suppose i am asking if anyone else has done this. i thought of this project last year, before the mini was introduced and it does have advantages over the mini in that it still allows max data speeds (in my opinion!) i just need to ensure that when i strip out the router board and connect it purely to 12v that it doesnt send 12v through the POE and into the dish - it doesnt need 48v as thats the voltage required due to cable length and driving the motor, snow melt etc. it will then be ...
The Child of Frank Starlinkenstein ...... LOL
i would love to be able to fit an internal rechargeable battery, so it would become truly portable albeit a little bit heavier and it would need to run the starlink for at least four hours before recharge to make it 'useful'
has anyone else had any other ideas re making changes to their starlink?
This the conversion attached to my motorhome (RV) - it's only temporary while I tested it.
![IMG_20240715_160906.jpg IMG_20240715_160906.jpg](https://diysolarforum.com/data/attachments/229/229894-2c5a3f6ab4455052dbd2833e5016c6cf.jpg)
![IMG_20240715_160916.jpg IMG_20240715_160916.jpg](https://diysolarforum.com/data/attachments/229/229895-d90dd478a0183c1e52538346702d9257.jpg)
One of my earlier projects re the one cable solution![IMG_20240605_113318.jpg IMG_20240605_113318.jpg](https://diysolarforum.com/data/attachments/229/229896-37a1ba90ab5aeb1ecde3b75078bbc1f0.jpg)
![IMG_20240605_113301.jpg IMG_20240605_113301.jpg](https://diysolarforum.com/data/attachments/229/229897-6f7046eee91a4c19c2311f2264b2f54b.jpg)
