Hi,
I need to enable/disable the internal "dynamic power reduction" algorithm using the ModbusTCP protocol. I found only the modbus address for the register of fixed percentage power limitation (0-100%).
Do you know if it is possible to activate/deactivate this algo only from inverter service web page, or if there is a holding register for activating/deactivating dynamic power control of the inverter, please?
In the activated mode, the inverter itself monitors the so-called "Maximum feed-in power," ensuring minimal overage power injection into the distribution network. Thank you for your responses.
