Rebus Stone
- Oct 19, 2022
- 4
We’ve just had a new GroWatt inverter and 6kw battery installed.
It’s set to “load first” and during the day can see everything working as it should i.e. using battery when PV not generating - although there’s often mismatch between what the app says is being used/imported and what our smart meter says.
But the main thing is that in early evening the battery switches to something called ‘reserve mode” on the app, the battery stays at 100% all night. So we don’t get to use the stored power in the battery which is what we want to do.
Also frustratingly on the app when I try to change any settings my password is not accepted (have tried the one I set the app up with and also some our installers suggested but none work!) so the only changes I can make are on LCD screen on the inverter. I’ve emailed GroWatt several times but no reply.
Any ideas?
Any ideas?
