Growatt SPF 3000TL LVM hooked up to a EG4 battery 24v system.
System works fine, on PV. Charges/discharges the battery, and runs the loads as it should.
When I plug it into an outlet, it doesn't accept? the incoming power from the grid, unless I turn the inverter switch off. Then it will charge from grid and PV at the same time. If I turn the inverter back on, it stops the grid input, and will continue to work fine on the PV. I've ran through the settings and just can't find something that jumps out at me I need to change.
1 is SBU
14 is SNU
Is this normal behavior? Or do I have a setting wrong?
1 is SBU
14 is SNU
