Hi guys, need a little advice over a building i am doing, got so far 4 solar panels 480 watts each, they will go with 4 lifepo4 280 Ah batteries build by myself from chinese EVE 3,2V cells. Now the question is: should be better to split the system into two 12V battery banks (for two different solar chargers controllers and 2 inverters 3 and 4Kw) or should i put the 4 batteries together? Got so far a 60, a 40 and a 30 amp solar controller, how can i combine them for the 4 batteries? Got so far (all 110V) a induction stove, 4Kw (not planning to use the two burners at the same time, so not going to the 4KW but only 2Kw), a water heater 1.44Kw, 110V fridge 7.3CF, microwave 1.2KW, Mini split, 1Kw, water pump, lights and laptops-tv another 1Kw. Expecting to go for two days with my batteries full (close to 16Kw total power or 1120 Ah). Thanks for any help. PD: you can point me to a similar setup from any of the guys here in the forum too.
