Aridom82
Learning addict
I have 3 Voltronic Max Axpert 8kw. In SBU mode, they will get the power they need to function (40w each, 120w in total), from solar when is available, but when the night comes they power themselves from the grid, even if the battery is full. It bothers me using 1-1,5kwh from the grid every night so i found a solution.
The solution is to set them up in USB mode, utility first, and put a contactor in the AC in that is controlled by a device that reads the battery voltage and switches it on when the battery is low, and switches it off when the battery has charged enough. I tried to use the dry contact on the inverter itself but is not fast enough so i have made an Arduino module with a voltage divider to read the battery voltage and a relay module to control the contactor.
So normally the contactor in the AC in is off so the inverters get all their power from solar or the battery. And when the battery reaches the low voltage switch we want, the arduino switches the contactor on and the inverters start using the grid until solar energy charges the battery over the reconnect voltage we want.
I know that people use solar assistant with home assistant to control devices based on battery voltage but is gonna be a while until i figure them out, for now the arduino module is working fine and i have eliminated completely all grid power use.
![arduinorelay.jpg arduinorelay.jpg](https://diysolarforum.com/data/attachments/168/168889-083df1c7f1031452eea6231aa8b76ce5.jpg)
