Have a few (6) 7s 20p (18650) batteries that i have built over the last few days using batteryhookup nickel fuse with spot welding.
finally got my bms's in the mail and wired up last night, easy enough i think?
now my issue is if i check the voltage at the xt60 (Bms) connector i get 18.6v.
These are to be 24v batteries.
if i check voltage directly at the battery i get 26.2v (good?)
if i check voltage at the other side of the battery directly i get 17.6v
ive tested each cell over and over again and each cell is at storage mode of 3.7v. I put the cells in storage mode as i tested each cell using 2 xtar vc8 chargers,
took me months as i have thousands of 18650 cells.
Im going to look over the entire battery AGAIN!! tonight.
Im missing something or i dont understand WTF im doing and quit before i burn the house down!
another question i have is do i need to connect the negative of the bms to each cell?? or can i connect it to one cell as they are all connected with the nickel strip?
