Thanks to this Forum and @SenileOldGit, I have discovered the joy of using MultiSIBControl on a laptop. It only supports Pylontech batteries, so when the EG4 LifePower4 Communications Hub came out, I was hoping that would allow MultiSIBControl to talk to the EG4 batteries. The EG4 communications hub talks to the two LifePower4 batteries perfectly, but I am not able to get MultiSIBControl running on my PC to talk to the EG4 communications hub.
I do have the communications hub set to PYLON
My PC, using the supplied EG4 USB-RS485 cable, can talk to the batteries and I'm using that same USB-RS485 cable in my attempt to communicate with the EG4 Hub. Has anyone else tried this setup? Maybe I should try the cable that @SenileOldGit used in his original post?
Any suggestions are appreciated!
EDIT: I can also communicate between the PC and the EG4 Communications Hub to download the battery data using the supplied EG4 USB-RS485 cable and the BMS_Test software, when the hub is in EG3 Protocol mode.
