gaveupontv
EG4-LifePower4 Lithium Battery | 12V 400AH | Server Rack Battery
EG4 (12V/400AH) LifePower4 BatteryEG4 Lithium battery 12.8V (12V) 5.12kWh with 400AH internal BMS. Made of UL Listed Battery Cells. Off Grid Solar Batteries - Off Grid System - Solar Batteries for Home - Lithium Solar Batteries - Deep Cycle Solar Batteries - Power Reserve - Solar Panels Plus...
![signaturesolar.com](https://cdn11.bigcommerce.com/s-bi8c0htqsn/product_images/signaturesolar-solar-reg.png?t=1673984423)
I believe that Renogy said I should get 2500-3000 watt hours a day with my 6 (100 watt panels) system. I wanted to get the new A cells and put together a 302 amp hour battery, but they are out of stock now. It would be around $900. But this battery is 400 amp hours and I think it has a 200 amp bms, so am I correct that this is enough to run a small microwave 700-800 watts I think that I had previously planned to run my generator for? The battery I had planned to build only had a 100 amp or a 120 am bms.
This $1450 battery doesn't have the led screen that tells everything going on with it, but I will have that Renogy One screen that should tell me everything I need to know.
