Do not ever discharge below 2.5V and never short your cells! You'll destroy them.
Charging the cells to 3.65 should have properly top-balanced the pack. But please, be more specific here. Provide step by step process on how you did that.
Check your busbar connections. If a busbar is heating up you need to redo it by cleaning the cell terminals and the busbar and reassembling it with the proper torque. Post a few pictures of your battery to see if there is something obvious that should be corrected.
And let's not rush into that, but based on the fact that you've taken cells from Aliexpress I assume that these are of bad quality. They are likely to be with higher IR and lower than the advertised capacity. And are very unlikely to be matched, so there will be a pretty high difference in the capacity among them. There are topics for recommended suppliers in the forum. It would be better if you have looked at them before purchasing the cells.
To sum it up - start by verifying that the busbars are properly installed and by providing details on how you did the top balancing.
