Hi Guys, has anyone had the experience of a 4S 100A Jbd Discharging only one string to 0 volts. ?
discharged a 40ah Bank completely disconnected from any load in 2 weeks
seems the balancer is going nuts.
Nope. The balancer should only work on the HIGH voltage cells. The most likely cause is a failed cell that is internally shorted and can't retain a charge.
It's POSSIBLE it's the BMS, but the most common cause of the vast majority of cases is failed cell.
