Berseker
- Mar 22, 2020
- 268
So i have a nearly 2month old pack working ok.partially offgrid. With 3600w of solar supporting charging.inverter was set to charge cells to 3.55v
So owner moved it to a new location with stable grid and pack ended up cycling very light and staying at fully charged state for extended periods of time.
So observed 3 cells voltage dropping to 3.35v while other cells are 3.51v.
Attempted to top balance the "low" 3 cells and they took about 5ah before getting filled up and voltage spiking to 3.6v....and dropping quickly to 3.45v and then 3.37v after about 4minutes
So my question is, my theory is that the 3 cells may have suffered some damage from the 3.55v charge voltage and staying at 100% soc for extended period of time.
Is this theory correct, if yes..is it permanent.
Have reduced the pack voltage to 55.6v/3.48v . Set trigger balance voltage to 3.34v and 0.02 delta and is observing the pack further.
Any tips or thoughts is welcome
