TheRealGomez
Hello All, I have a question that I cannot find the answer for anywhere. Perhaps someone here can help. I have a 24vdc~ gate motor, a 24v50ah Lifepo4 battery, and 120vAC line (unstable). Since my motor load is also 24v, Can I just put a Lifepo4 charger between the line and the battery? Power would go Line-->Charger-->Battery-->Load. That way, when the line fails, the load wouldn't know until the battery runs out. Also, since the charging voltage of the 24v Lifepo4 is around 29v, should I put a 24vdc buck converter between the battery and load to stabilized the voltage delivered to the motor?
Any guidance is greatly appreciated.
EDIT: As an update, I'm looking at this charger: https://a.co/d/9BSfmPT and this buck: https://a.co/d/eVTNRsB
