Rdooley79
- Feb 25, 2020
- 10
What would you get if building a 400-800w system from scratch?
I need everything, Post links if you've got them to the components you'd use to build up a system.
My 30ft motorhome has a lot of room space for panels. Start off with four and maybe add four more. Maybe have a couple portable panels that can be set outside.
Looking at the 400W system Will Prowse has laid out but are there better components now than when this was written?
Will's reccomendation:
Id like to be able to run a decent PC and LED monitor as well as the fridge (Norcold LP/110v) with some juice to spare for LED lights and charging cell phones and tablets.
AC would be awesome from solar but the battery and panels would be a lot.
I'll be using the coach year around and will be in hot and cold climates.
What would be your system of choice if buying today?
Thanks
R
![www.mobile-solarpower.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/400-watt-system-exa_orig.jpg)
RV Solar Power Blue Prints
Building a vehicle mounted solar power system? Let me help.
Thanks
R
