Thank you. Yes, it's a rubber membrane and we'll be screwing the mounts into the roof and applying generous amounts of dicor. Seems Renogy recommends just standard Z brackets for a 400W panel. Fortunately the orientation of the panel on my roof is such that the brackets will be run down the "flat" edge.
Aluminum angle iron. One pic the foot is tucked under, the other pic the foot is outside. You want your not-tucked so you can re-do the Dicor yearly.
Mine roof is flat, so I ran side to side, but front to back is the same idea. The self-tapper screws miss the glass panel, so be careful of that. These are just #8 self-tapper metal screws. Been on here a few years. I have done this on other vehicles too.
Shown is, first pic, is the front edge, short edge of a 100w panel.
Second pic is the side, long side, with just a short piece of angle holding it. Same on other side, so 3 attachment points. The end of the panel hangs off the back is why I attached to sides. You see that it does not take a lot of metal to hold it to the roof. These are taped to the roof, but you will screw yours to the roof.
I have other panels that are like the first pic, front and rear of panel only attached at the short side. Leave room for air to flow under for cooling.
Well, here is the 3rd pic of the other side bc it is funny how small the bracket is. It holds, barely, but never had any issues with it.
![IMG_3952.jpg IMG_3952.jpg](https://diysolarforum.com/data/attachments/222/222748-e434a23309fa9376c64ab125ab96923c.jpg)
The vent cover is an issue bc it does make a small shadow on the panels except for around noon, but I dont have problems getting batts back to 100% so have left it on there, the cover is so useful for driving in the rain with vent open. The Air Cond would be a huge issue for shading, so is why the panels hang off the back so far from AC unit
