MPP Solar
plr
I run MPP Solar All in One during the day and charge up my batteries. At night I turn off the MPP Solar is there any way to access the energy stored?
Energy stores in the batteries. I am considering buying MPP Solar but I am considered about the high idle consumption.
I assume at night or on cloudy days and I if I turn off the. MPP Solar I will be unable to access any power from the batteries. Am I correct or way off?
As soon as the AC input and a battery is connected the charge half is on. (There is no switch to turn on or off)
You get to manually flip the inverter part on and off. So if you want to use the stored power from the battery, turn the inverter on and connect anything you want AC to the output.
Ok thanks Jason that’s what I thought..guess I will go with an outback.
Sorry for any confusion. I try not to post when falling asleep or just waking up?
