ChuckHomeLab
- Apr 20, 2022
- 25
Is there a setting on the 3000EHV-48 to limit the overall current being pulled from the grid/generator? Option 11 sets the maximum utility charging current. So I can regulate the current going to charge the battery. But as soon as I plug the inverter into the grid/generator, it goes to bypass mode, so all my loads are running from the grid and it's charging the battery at the specified current. I would like to be able to set a max current it pulls from the grid to charge and run the loads.
Is it possible to disable bypass mode and have the inverter only pull loads from the battery? Then when the inverter is plugged into the grid it only charges the battery.
