Solarsurfer992
Hi. I am planning a system to power my travel trailer at an off grid campsite.
Initially 400w of panels, MPPT controller with 2x100wh LiPo batteries and a 2000w pure sine wave inverter. Panels, batteries etc to be mounted on a small shed 25 to 40’ from the trailer.
Trailer requires about 40 amps DC power 12v (peak usage) plus 120v TV and laptop, USB chargers etc.(will not be using AC, microwave etc.). Trailer has a 12v deep cycle lead acid battery on board. The converter requires 8 amps at 120v for battery charging.
Intent, due prohibitive cost of wire for running 12v over that distance is to power the trailer with the 2000w inverter using the onboard converter to maintain charge for the onboard battery using the heavy duty 30 amp AC power cables that came with the trailer.
Mounting panels on the trailer is not an option as I intend to sell it and but a bigger one soon at which time I would need to upgrade solar power system.
Proposed system is based on calculated requirements and a practical budget, system can evolve as
needed. I am not looking for suggestions to build a gold standard system, just practical advice and suggestions to keep costs low and work satisfactorily.
