Operating Modes on Solis Hybrid Inverter
How do I set this type of inverter not to export power to the grid?
You will need to enable export power limitation feature and set the export power level to 0W.
Note, however, that will not _totally_ prevent any export - a brief export of power will happen due to the time it takes the inverter to reduced its output when a house load is switched off.
Good afternoon
I can't charge my batteries in "self user" on Solis inverter S5(5Kw) with a DIY LifePo4 S16 105Ah Battery with Daly BMS.
The Battery on Solis are configured as "Lead Acid Battery", and charges me from the GRID with the "Self User", even with settings "STOP" and "Not Allow charging from Grid".
I can't understand how to configure this crazy inverter. It seems that any configuration does something different.
I'm already tired of breaking my head.
I'm waiting for my new Seplos 100A BMS to connect via CANBUS to see if I can solve this problem once and for all.
The only way to charge the batteries so far, is setup the inverter in mode "BUCKUP", but then I have to put it in "Self User" overnight to discharge the batteries on the gridit. Doesn't make any sense.
The mode "Self User" does not do the proper functions. 1-Solar, 2-Batteries and 3-Grid
Anyone using a Diy LifePO4 16s 100A battery and this inverter can help me?
Thanks
Thank's SeaGal
I don't want to charge the baterry from the Grid, only by the sun.
What I read is that we shouldn't activate "run" if we want to charge from solar.
It's right?
No, just self-use mode will charge batteries from PV, assuming more PV is being generated than your house usage.
Well... I don't think they're doing that in Self User
Now, even with the batteries, after the sun goes down, it turns off.
Damn inverter, I'm fed up with this inverter.
Is the smartmeter connected? What are the meter settings on the inverter? It says your house is using 0W so something's not right
Also, it doesn't look like your CANBus connection is set up correctly; it might not be detecting your battery correctly unless you have configured the Solis to recognise your battery comms.
Sometimes consumption appears in house, other times it doesn't.
But it is not the consumption, it is limited in the inverter to not injecting into the grid
As I say Damn inverter.........
I don't have CANBus connection.
Solis configured as Lead acid, but BMS daly manages battery charges Diy LifePO4 S16 100A.
OK so there's a problem with the smartmeter. If it can't measure power use by the house, the inverter can't know what power it should output.
How did you wire the meter? Please make a schematic.
Basically and sorry for my drawing that looks like it was made by my son.
The meter is a sdm120ct and it is ok. I can confirm with Shelly EM that I also have installed on the grid
the difference in the meter is the is from (system 2) that is producing what the house is consuming.
The schematic looks correct
On the photo, your SDM120 displays 0.0W which would be unusual for a house
What does this mean?
I see you have microinverters. This is similar to my situation: I have a Solis S5 and a Fronius inverter with panels on another roof.
One little detail about Solis that is not mentioned in the manual is this:
- If you set maximum export power in Solis to "X" Watts
- If your microinverter installation (or my Fronius) produces a lot more than "X", the house uses little power, as a result more than "X" watts are exported to the grid even if the Solis produces nothing
- Solis detects this, thinks it's an anomaly, and shuts down. But it doesn't say it is shut down! It just stops working.
Solution is to set "Max export power" to more than what your microinverters can produce.
Thank you very much for all the help.
Today I got back from Solís and installed a BMS Seplos V3 and realized that the CT was messing everything up.
If you live in one direction, the CT already charges the battery and if you reverse the direction, it stops charging and consumption remains at 0w.
But just change the phase with the neutral in the CT connection and I'll get crazy values.
Any tips or manual for the correct configuration direction.
Regards
It might be what I said in the previous post. Try to set the export limit on the Solis to a bit more than what the house will export when your microinverters get full sun.
is there any way to prevent a hybrid solis inverter feeding the home power when it has full ish batteries ?
I wanted to use the -ve cost Octopus grid this afternoon, but could not find a way to prevent my inverter/batteries from feeding my home demand ? ( taking the “free” power to use the sel-clean ( lots of KW) on my ovens.
i wanted to keep my batteries for this evenings “peak” time.
I did try setting an export time with 0A discharge but it still fed my home power demand.
i ended up dis connecting the ac breaker from the inverter. but this also stopped solar to battery and gave a fault indication.
Steve
That's weird since it is supposed to charge the battery from solar during a blackout...
You could set it to charge using Time of Use but when the battery is full it will still export.
Besides that, j ust disconnect the meter, it'll go into safe mode :ROFLMAO: You could even put a relay on it triggered by negative octopus rates!
