If you saw my post about the NewtiPower $700 Amazon server rack battery than this will look very familiar. It appears to be the exact same case, BMS, cells and manufacturer, with just a different name screen printed on it. Still a 16s and still B grade cells. Here's the pictures
![1000030369.jpg 1000030369.jpg](https://diysolarforum.com/data/attachments/229/229975-7ae5af7fdd06ab1f991ab372c9eb1d16.jpg)
![1000030383.jpg 1000030383.jpg](https://diysolarforum.com/data/attachments/229/229976-34a47ab2969cb8e330481f6b2dab30c4.jpg)
Same ridiculous black goop and electrical tape covering the terminals.
![1000030384.jpg 1000030384.jpg](https://diysolarforum.com/data/attachments/229/229977-bafb89d744a049da7fca7d2b3b41e373.jpg)
Same scratched off QR codes and packing tape holding the balance leads. Note the huge cell voltage mismatch on the test tags. Yikes.
![1000030387.jpg 1000030387.jpg](https://diysolarforum.com/data/attachments/229/229978-bbe784345e6a5c3176472fe3d7c4391e.jpg)
I couldn't get the fiberboard all the way out because it's glued down so much and I didn't want to rip the balance leads out but it is in fact 16s
![1000030390.jpg 1000030390.jpg](https://diysolarforum.com/data/attachments/229/229979-ddeede0dfd593521b9e4ac3158881e37.jpg)
Looks like copper coated lugs not full Copper as well. Unless that is just tinning from The Wire, I can't exactly tell
Just like in my other post I will update this with a capacity test when I get around to it. Takes quite a few hours with my little tester
